It is currently Sun Jul 20, 2025 10:04 pm
PostPosted: Sun Jan 09, 2005 8:16 am
Do you seperate each piece or do you put two pieces together? For instance, a side set of mahogany would be placed together for one level or seperated for 2? i would assume 2 but wanted to check.
PostPosted: Sun Jan 09, 2005 8:22 am
State: BC
It would probably be easy to open the bookmatch and sticker the sets as 1 level. keeps the pile low&wide (easier to put weight on) You don't want any sets sandwiched or they can mold/rot/stain where the air cant hit them
CVT Inc.
PostPosted: Sun Jan 09, 2005 10:02 am
Frank you assumed correctly. Each piece is separated by stickers and make sure to keep the stickers lined up. With that jig you won't have to worry about weight.
PostPosted: Sun Jan 09, 2005 11:41 am
Be sure to use stickers with a low-tack, removable adhesive. That way you can get them off later. Stay away from NASCAR auto stickers like STP, DuPont, Pennzoil, stuff like that.
PostPosted: Mon Jan 10, 2005 9:52 am
Don,
I used to use Cyano but my tongue kept getting stuck to my eyebrows. (wishful thinking). Anyway just remember not to lick the stickers or you will get splinters. I never had any use for the low tack adhesives as they all but disapeared in the fire.
this is just a joke o.k.
PostPosted: Mon Jan 10, 2005 3:18 pm
